post #1 of 30 (permalink) Old 03-24-2012, 03:53 PM Thread Starter
Power Commander Map
I have a 2006 R6 Raven with a M4 slip on with a K&N air filter. Does anyone have a good custom map for a power commander III I can use? All feedback would be appreciated.
2006 R6 Raven
Mods: Pig Spotter Mirrors, Red Tire Decal, Puig Smoke Windscreen, Proton Flush Mounts, Pro Grips 719, Fender Eliminator, K&N Air Filter, AGV Brake/Clutch Levers, M4 Slip-on Exhaust, GPR Steering Damper, Michelin Power 2CT, PCIII (Still a work in progress)
Gear: Scorpion Exo 1000 Helmet(Red/Blk/Wht), Scorpion Tornado Jacket(Red/Blk,Wht), Alpine Stars Gloves(Red,Blk,Gry),Sidi Boots(Red/Blk/Wht).
ccobb575 is offline
post #2 of 30 (permalink) Old 03-25-2012, 04:41 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Re: Power Commander Map
Are you noticing any issues at all? Bouncy idle? etc.
Just changing the slipon on an 06+ doesn't change hardly anything, the bike still has both cats and the stock muffler box!
Strap on some MJS headers or an M4 midpipe and we'll talk about a nice map for ya
Anyway, if you want to try a map you can try the Two Brothers slip-on map: http://likestuff.globat.com/M418-020.djm (right click, save as)
Remember, that map is doing NOTHING to try and fix your bouncy idle (like these 4's in 500RPM to 2250RPM):
And it's also doing nothing to prevent pop and gurgle on deceleration (20's in 0% from 6500rpm to 14500rpm).
Don't forget to get smog block off plates from AGG on here, and rip out your entire AIS system (remember to remove screws, reeds and baskets but reinstall the reed mount block before installing the smog block off plates). Also don't forget to plug/cap the AIS feed nipple on the airbox.
-Jamie M.
toysareforboys is offline
post #3 of 30 (permalink) Old 03-25-2012, 06:21 PM Thread Starter
Not really noticing any problems...guess my next mod will have to be the mid pipe...
2006 R6 Raven
ccobb575 is offline
post #4 of 30 (permalink) Old 03-25-2012, 06:36 PM
Bike: 07 R1
If you're not noticing any problems then don't worry about anything Like I said, changing the slip on is just cosmetic on the 06+. When you're ready to REALLY make some noise and get a mid pipe, then you'll need a map
-Jamie M.
post #5 of 30 (permalink) Old 03-25-2012, 09:00 PM Thread Starter
Just listened to a YouTube video with the M4 and mid pipe...it is loud. I'll just wait until I'm done doing mods
2006 R6 Raven
ccobb575 is offline
post #6 of 30 (permalink) Old 03-25-2012, 09:06 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
What are the odds that someone has the same bikes as you with the exact same mods as you living in a similar climate and elevation as you and frequents this forum? Slim.
Either try out some of the maps that have been posted on this forum (or the dynojet website) already and get one that suits you, or pony up for a dyno tune... Or sell that POS power commander, buy a Bazzaz zFi and AFM module and make your own maps every day of the week.
  • What's the difference between an R6 and an R6s? HERE
  • Should I start on a 600 or a 250? HERE
  • How do I ask the forum a question and actually get an answer? HERE
  • Where do I find a map for my Bazzaz? HERE
  • Should I get a 520 kit for MOA POWAH? HERE
  • How does rotating mass work? HERE
pickpocket293 is offline
post #7 of 30 (permalink) Old 03-25-2012, 09:07 PM
Bike: 07 R1
Originally Posted by toysareforboys View Post
When you're ready to REALLY make some noise and get a mid pipe..
Yep, it IS loud The problem is that most slipon's designed for 06+ is they don't really quiet anything down much (the Akrapovic being the exception), because they assume it being a slipon, you'll be leaving the stock muffler box in place (which you of course ditch when installing a mid pipe or MJS headers!), so that's why they are so loud
My 08 R6 full Yosh R-55 system, baffle removed:
My 09 R6S with the equivalent of MJS headers (or mid pipe, same thing) and Two Bro's 10" slipon with P1X sound reducer "baffle":
-Jamie M.
post #8 of 30 (permalink) Old 03-25-2012, 09:10 PM
iRun
Are we posting videos? I'm game...
This is from my squidly days... 2004 R6 with just about every bolt-on mod you can buy, topped out at 145.
EDIT: full yosh exhaust, for what it's worth.
post #9 of 30 (permalink) Old 03-26-2012, 05:49 PM Thread Starter
http://www.youtube.com/watch?v=1O2ThKZwWBc
http://www.youtube.com/watch?v=FI4djEs1Cws&hd=1
-Jamie M.
This are good vids...I need to make one so you can hear mine....my M4 slip on is crazy loud and it still has the cat...it may be to loud if I remove it and get a mid pipe... I don't know...but do you think the 520 sprocket change is worth it?
2006 R6 Raven
ccobb575 is offline
post #10 of 30 (permalink) Old 03-26-2012, 06:02 PM
Bike: 07 R1
Absolutely! You drop all that weight of the heavy chain, heavy sprocket. Go -1/+2 or whatever you fancy and it makes your R6 feel like an R1! The difference is mind blowing. Once you go black you don't go back. Er I mean once you go 520/-1/+2 you won't go back!
-Jamie M.
06-07 (08-09 too?) R6 v Power Commander III USB XRayHound Bike Parts For Sale 4 07-05-2011 02:52 PM
07 r6 freestlye cage and power sub frame cage and power commander and etc R6BryanR6 Bikes + Parts + Gear Wanted 0 09-30-2009 01:13 PM
Need pinout for Power Commander 9v power supply Jdmturbo General Discussions 1 09-20-2009 01:26 PM
dyno (no Power Commander with stock 02) vs Power commander no 02 JayK Exhaust and fuel delivery 2 04-19-2009 06:19 AM
Mid range power with a power commander? evoix2r6 Exhaust and fuel delivery 2 06-06-2007 01:41 PM
